It is almost impossible to live without water, especially with the way it is delivered to homes and businesses throughout the United States. People depend on a readily available supply to do things like practice personal hygiene, clean the house, and cook. Having a broken water line to your home can create big problems for you and your family.
The main line that runs to your house is important in providing a constant source of water. These lines are generally strong and durable. They are not easily damaged, but you cannot rule out the possibility that something could happen to them. Because a break in the main water line does not happen very often, most people do not know what causes the issue.
What causes problems with the main water line?
Many things can cause your water line to become blocked, broken, or damaged, including deterioration or corrosion of the pipe, tree roots, and incorrect installation. Regular wear and tear, soil shifting under the surface of the pipe, sediment buildup, deposits of minerals, and frozen pipes can also cause this problem.
How noisy pipes affect your main line
Noisy pipes are not usually a huge problem, but if you do not get them fixed, they can lead to bigger troubles. When air enters the main water line, it makes noises and creates vibrations, which can cause long term and permanent damage. The easiest way to fix this problem is to drain the line by turning off the water for a short period and then refill it afterward.
Low water pressure in your main line
In order to fix this issue, you have to determine the source of the reduced pressure in your supply. Low water pressure can be caused by leaks, among other problems. Leaks occur due to corrosion in the pipes or loosened joints. Have a leak repaired by a professional plumbing company as soon as possible if you find one so they don’t lead to larger ones.
Low water pressure can also be caused by clogs and supply problems from the local municipal department. This is a tricky problem to diagnose and solve, so it is best left to a professional.
Frozen pipes and main water line issue
You may wonder if having burst pipes can affect your main water line too. If your pipes have become frozen, you should turn off the water to your home. The water line needs to be repaired immediately. Unless you have the experience or credentials yourself, call a trusted plumbing company to help get the pipes repaired.
If you go on a trip, or you live in another place during the winter, your home runs the risk of having its pipes freeze. When the thermostat is turned off, water will freeze and block the pipes. Heat tape is available for you to wrap your pipes to help keep them above freezing. If the pipes are already frozen, keep the tape on them for 24 hours or more to melt the ice and get a normal water flow.
If you need help with your plumbing or gas lines, contact the professionals at Cole’s Plumbing today. Our expert plumbers provide the best services at the best prices. Call/text us today at (972) 210-9033 or complete the Get an Estimate form and let us know how we can help you.
